1967 D100 318 Transmission Crossmember
- 67D100Pickup
- City: Noble
My truck hasn't had a transmission crossmember on it since I've owned it. Does anyone have a picture of what it should look like, installed?
Jeff
Jeff
- City: Binghamton
- State: NY
Re: 1967 D100 318 Transmission Crossmember
My 65 doesn’t either. If the bell housing is mounted to its own cross member there shouldn’t be one under the tail shaft housing. I’m not sure what year dodge stopped doing it this way.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
It changed in 1969 on light duty trucks.
- City: Binghamton
- State: NY
Does it make a difference depending on engine?
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
No
- 67D100Pickup
- City: Noble
Interesting. Yes, my bell housing is bolted down but I rebuilt the motor to 280HP and about the same torque so I fabricated a crossmember with the assumption it used to have one, and would need one. Maybe not?BigBlockTrucks wrote: ↑Thu Aug 05, 2021 2:50 pmMy 65 doesn’t either. If the bell housing is mounted to its own cross member there shouldn’t be one under the tail shaft housing. I’m not sure what year dodge stopped doing it this way.
I was fishing to see how others were mounted so I could approximate the rubber dampers.
Jeff
No truck before 69 had a manual tranny crossmember, whether slant six or 413, only auto tranny trucks.
- City: Binghamton
- State: NY
67D100Pickup wrote: ↑Fri Aug 06, 2021 4:51 amInteresting. Yes, my bell housing is bolted down but I rebuilt the motor to 280HP and about the same torque so I fabricated a crossmember with the assumption it used to have one, and would need one. Maybe not?BigBlockTrucks wrote: ↑Thu Aug 05, 2021 2:50 pmMy 65 doesn’t either. If the bell housing is mounted to its own cross member there shouldn’t be one under the tail shaft housing. I’m not sure what year dodge stopped doing it this way.
Jeff
What are you planning to bolt the mount to? Unless someone put a newer tranny in it there is nothing to bolt to on the tail shaft housing.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
How about a big hose clamp with a piece of tire sidewall between?BigBlockTrucks wrote: ↑Fri Aug 06, 2021 10:46 am67D100Pickup wrote: ↑Fri Aug 06, 2021 4:51 amInteresting. Yes, my bell housing is bolted down but I rebuilt the motor to 280HP and about the same torque so I fabricated a crossmember with the assumption it used to have one, and would need one. Maybe not?BigBlockTrucks wrote: ↑Thu Aug 05, 2021 2:50 pmMy 65 doesn’t either. If the bell housing is mounted to its own cross member there shouldn’t be one under the tail shaft housing. I’m not sure what year dodge stopped doing it this way.
Jeff
- City: Binghamton
- State: NY
Essential parts should be held with ratchet straps. Non essential parts are ok with bungee cords or duct tape.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- 67D100Pickup
- City: Noble
Maybe somebody switched the tranny. There are two mounting holes near the back.BigBlockTrucks wrote: ↑Fri Aug 06, 2021 10:46 am67D100Pickup wrote: ↑Fri Aug 06, 2021 4:51 amInteresting. Yes, my bell housing is bolted down but I rebuilt the motor to 280HP and about the same torque so I fabricated a crossmember with the assumption it used to have one, and would need one. Maybe not?BigBlockTrucks wrote: ↑Thu Aug 05, 2021 2:50 pmMy 65 doesn’t either. If the bell housing is mounted to its own cross member there shouldn’t be one under the tail shaft housing. I’m not sure what year dodge stopped doing it this way.
Jeff
Doesn't the NV 4500 have a couple of holes on the tail shaft? Maybe you have one of those?
Coat hangers and bailer twine for me.....BigBlockTrucks wrote: ↑Fri Aug 06, 2021 2:26 pmEssential parts should be held with ratchet straps. Non essential parts are ok with bungee cords or duct tape.
- swptln
- City: East Brookfield
- State: MA
Then it's a late model tranny, only 69-up had a tail shaft mounts. But now that I'm thinking about this.....a late model tranny wont fit a hydraulic bell as the input shafts are different lengths and splines......so, there's a possibility that someone may have changed the tail housing for some weird reason.67D100Pickup wrote: ↑Fri Aug 06, 2021 3:43 pmMaybe somebody switched the tranny. There are two mounting holes near the back.BigBlockTrucks wrote: ↑Fri Aug 06, 2021 10:46 am67D100Pickup wrote: ↑Fri Aug 06, 2021 4:51 am
Jeff
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
- 67D100Pickup
- City: Noble
That is strange. FYI, I also think the engine was swapped before. Maybe the engine and tranny were swapped as a set from something else?
Jeff
Jeff
- City: Binghamton
- State: NY
It wouldn’t have been a set with later model tranny and a hydro bell. Assuming the pilot shaft is actually reaching the pilot bushing you may be better off only because of clutch availability. The old ten spline clutch is almost obsolete.67D100Pickup wrote: ↑Tue Aug 10, 2021 5:05 amThat is strange. FYI, I also think the engine was swapped before. Maybe the engine and tranny were swapped as a set from something else?
Jeff
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Pictures go a long ways to help determining what's what.
- swptln
- State: MA
The 10-spline clutch is still available through a number of places, just not at your local parts stores. There's a couple places on eBay, McLeod has them also.BigBlockTrucks wrote: ↑Tue Aug 10, 2021 8:07 amIt wouldn’t have been a set with later model tranny and a hydro bell. Assuming the pilot shaft is actually reaching the pilot bushing you may be better off only because of clutch availability. The old ten spline clutch is almost obsolete.67D100Pickup wrote: ↑Tue Aug 10, 2021 5:05 amThat is strange. FYI, I also think the engine was swapped before. Maybe the engine and tranny were swapped as a set from something else?
Jeff
Mark D.
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
Bud Thorp sells them too.swptln wrote: ↑Wed Aug 11, 2021 2:03 pmThe 10-spline clutch is still available through a number of places, just not at your local parts stores. There's a couple places on eBay, McLeod has them also.BigBlockTrucks wrote: ↑Tue Aug 10, 2021 8:07 amIt wouldn’t have been a set with later model tranny and a hydro bell. Assuming the pilot shaft is actually reaching the pilot bushing you may be better off only because of clutch availability. The old ten spline clutch is almost obsolete.67D100Pickup wrote: ↑Tue Aug 10, 2021 5:05 amThat is strange. FYI, I also think the engine was swapped before. Maybe the engine and tranny were swapped as a set from something else?
Jeff
