New cam for 440
BigBlockTrucks
City: Binghamton
State: NY
New cam for 440
Post by BigBlockTrucks »
Anybody have suggestions for cam option to help wake up a 1977 motor home 440 that is otherwise stock
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: New cam for 440
I think higher compression pistons would benefit more than just a cam swap.
swptln
City: East Brookfield
State: MA
Re: New cam for 440
Post by swptln »
Depending on the pistons and compression ratio, it can wake it up, but I'd look at that first and go from there. Knowing your compression ratio, helps in cam selection. Too many factors to just say in general, compression ratio, lift, duration, lobe separation, etc.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
Volksnut
City: Winter Park
Re: New cam for 440
Post by Volksnut »
If you can check out Engine Masters on Motortrend, they covered it with there motor home 440 on episode "The 440 you can afford" They used a Comp cams (Thumper grind) with 107 lc and 227/241 @.050 duration and a 486/473 lift, Steve Dulchish (spelling) explains it.
Jim100
City: Kalamazoo/MI
Re: New cam for 440
Post by Jim100 »
How much do you want to wake it up is the question.My cousin had a motor home 440 with cast crank and low compression. We stuck installed aluminum intake and 750 four barrel and headers. In a two wheel drive life style era truck it was awesome. Not a drag strip type thing but pulled hard.
JJ
City: Lawton
Re: New cam for 440
Post by JJ »
Call Racer Brown Cams (410-866-7660), Jim Dorin will ask you about 20 questions for your application and send you a cam that will work perfect. I never use anything off the shelf any more.
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride&quot
