From what I have read here this starter is tough to find.
Poking through a mopar junkyard I found a direct drive starter from a 440 powered boat. It bolts up on my hydro bell and meshes well with the FW. It is a couple inches longer. I believe it is a prestolite design.
Just a little info for the board. It may be an option for some if you have clearance.
2 bolt starter for hydro bell
- City: Binghamton
- State: NY
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
