I’m getting ready to put the 440 in the place of the old poly? My question is will the hydro bell for BB sit happily on the crossmember that originally had a SB hydro bell attached? The bell is physically wider. I’m concerned if the mounting points are the same.
Thanks in advance for the input
Crossmember questions???
- City: Binghamton
- State: NY
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Crossmember questions???
I'm pretty sure they are the same & don't recall anyone ever needing to swap crossmembers.
- City: Binghamton
- State: NY
I’m on the same page of think they are the same. Before I pull the working small block I would like to know the new idea will work without looking for more parts while the truck is apart
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
BB Hydraulic Bell sits right on same holes as SB Hydraulic Bell
The bell housing cross member in your truck will work with the
big block hydraulic clutch style bell housing.
- City: Binghamton
- State: NY
That what I was hoping for. Thanks to all for the know how.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
And isn't easily changed regardless, since it is riveted to the frame!
