'67 318 PCV Routing
JLeather
City: Ijamsville
'67 318 PCV Routing
Post by JLeather »
I suspect my aftermarket PCV system is causing my cab tuning issues (too much idle bypass air). I want to return to a stock-ish system so I've ordered a new stock PCV but I don't remember how it was plumbed. Anyone got a pic handy, or can confirm that it was plumbed the same as most modern systems (PCV in one valvecover plumbed into carb base, breather in opposite valvecover)? I think I can gut the aftermarket PCV so it's just an elbow and then plumb the stock one between that and the carb base.
Re: '67 318 PCV Routing
Here is how it is set-up on my 1968 318 with Edelbrock 600 4 barrel
front port to driver side valve cover grommet/valve.
1968 EDELBROCK 600
1968 EDELBROCK 600
JLeather
City: Ijamsville
Post by JLeather »
Wally, do you know what p/n that PCV is? Based on RockAuto I ordered a V180. Will be trying it out this weekend if I can get the Jegs-brand PCV apart and turned into just an elbow.
Not sure actually, it is the same as the ones on the 71 and up Muscle cars. I have a couple original ones if you don't find it. Original is the metal style.
usually located on passenger side with breather cap on drivers. pcv runs to manifold vacuum
martincom
City: Five Points
Post by martincom »
To test your PCV valve: Pinch off the vacuum hose from the PCV with needle nose pliers. The idle speed should drop 50 - 100 RPM with a properly functioning PCV valve.
JLeather
City: Ijamsville
Post by JLeather »
martincom wrote:
Sat Nov 21, 2020 10:33 am
With the aftermarket PCV I'm dropping almost 250 rpm's vs. a capped hose...
