225 to 318 engine swap
I'm putting a 318LA where a 225 was in my 68 D100. I understand I have to change the motor mount brackets. Does anyone know if the perch is the same on the chassis for the 225 and the 318 where the motor mounts sit?
Re: 225 to 318 engine swap
Pretty sure they are.
Frame brackets are the same. You need the correct engine brackets
and insulators. Insulators can be sourced through any major auto supply
outlet.
If you have a manual tranny..... you'll need the correct hydraulic clutch
flywheel along with the correct size clutch components.
Thanks Friend. I appreciate the response. I believe strongly the flywheel is appropriate for my hydro clutch. However, is there any way to check the flywheel to be sure? I have the insulators; I'm having difficultly finding the brackets. I'll keep searching!
If the flywheel that you believe is appropriate is the flywheel that is currentlyvarbucci wrote: ↑Wed Nov 04, 2020 8:47 amThanks Friend. I appreciate the response. I believe strongly the flywheel is appropriate for my hydro clutch. However, is there any way to check the flywheel to be sure? I have the insulators; I'm having difficultly finding the brackets. I'll keep searching!
on the Slant 6, then you will need the correct flywheel for the A/LA series V-8
small block for the hydraulic clutch.
I have the engine brackets, flywheel and clutch stuff.
Hi Hobbcoble,
I acquired the flywheel and a bellhousing from someone on facebook market place. The flywheel had an 11" clutch on it. He claimed the came from mid 60s D100 with a 318 (no mention of LA or Poly). I'm having the flywheel balanced and cut. The both fit perfectly on the crank of my LA. There is room for the bell to slide between the flywheel and block. The flywheel has approx 174 teeth. It seems to be right. I wish there was some further way to know for sure. With out that, I guess I'll find out.
I'm understand the slant 6 flywheel wouldn't work. But the slant 6 bell housing looks the same as the new one I just acquired for the LA
Thanks, Vincent
Thanks, Vincent
The bell is the same for both engines. If the starter engages the flywheel that bolts to the crank, then all is fine.
Makes sense. Thanks
The latest issue with the swap is i put a new water pump on and now the water pump pulley doesnt line up with the other pulleys. I assume the pump shaft was longer on the orig water pump. I cant seem to locate a water pump with a longer shaft. All b body, a body and truck water pumps seem to have the same shaft length. Any ideas??
- City: Sacramento
Did you get this worked out? I have a 340 which is VERY similar to the 318 and indeed has the old 318 water pump, alt, power steering etc. I will be putting these pieces back on in the next week or so. I can take some pics to share. Everything should line up very easily. Can you explain what you have that isn't lining up? Alt, crank and fan? anything else?
varbucci wrote: ↑Fri Nov 06, 2020 8:53 pmThe latest issue with the swap is i put a new water pump on and now the water pump pulley doesnt line up with the other pulleys. I assume the pump shaft was longer on the orig water pump. I cant seem to locate a water pump with a longer shaft. All b body, a body and truck water pumps seem to have the same shaft length. Any ideas??
Two water pump styles. Cast Iron and Aluminiumn. Cast Iron up to 69/70 ish and Aluminiumn for 70 ish and up. Correct water pump to work with whatever pulleys you are using.
