looking for more speed
- quickgraffix
- City: stockton
I currently have a 225 slant six with 3 on the tree i top out @65mph 6500 rpm I am building a 318 to put in it and I definitely want to keep it a manual transmission I could use a little direction..
Re: looking for more speed
We could use a little more specificity. Is this an LA318 or a poly A318? Did the engine come out of a manual or auto trans vehicle? What year is the truck? Is this a pre-'69 hydro bell or a 69+ manual clutch?quickgraffix wrote: ↑Wed Oct 28, 2020 10:48 pmI currently have a 225 slant six with 3 on the tree i top out @65mph 6500 rpm I am building a 318 to put in it and I definitely want to keep it a manual transmission I could use a little direction..
If it is a D100 with a 5-bolt pattern, I'd get a Dana 8-3/4 axle (with the drop-out carrier) which makes changing axle ratios MUCH easier.
- quickgraffix
- City: stockton
on the side of the block it has a 2536030 318-5 it came out of a 86 ram charger automatic my truck is a 69 d100 3 speed manual
OK, so it's an LA-318. I am assuming you know to have the crank bored for the pilot bushing.quickgraffix wrote: ↑Thu Oct 29, 2020 12:42 amon the side of the block it has a 2536030 318-5 it came out of a 86 ram charger automatic my truck is a 69 d100 3 speed manual
With the 318, you'll get enough torque to handle a taller axle ratio.
I'd look for at least 3.55 unless I was going for smaller diameter tires to lower the truck.Gear ratios available on the 8-3/4" axle through the years include: 2.76, 2.93, 3.23, 3.31, 3.55, 3.73, 3.91, 4.10, 4.56, 4.89, 5.17, 5.57. On OEM gear sets, the ratio is usually stamped on the ring gear edge. Ratio may be determined by the number of teeth on the ring gear divided by the number of teeth on the pinion gear or by counting the ratio of the number of turns of the pinion relative to one turn of the axle shaft. Source: https://www.bigblockdart.com/techpages/875axle.shtml
With the '69, you have a mechanical clutch linkage. What do you plan for a transmission? For freeway speeds, you have two choices in 4-speeds: the NP435 truck transmission and the A-833 automotive trans. For the latter, you'd probably need an automotive bell housing which would likely work with that truck. The 69+ NP435 with a matching LA bell is a sure fit. Check your Private Messages.
What is your current axle gear ratio? There were a lot of half ton Slant 6 three speed manual
trucks that had 3.91 gears. You're saying that the RPMs are 6500 at 65mph?... Really??...
Do you have an accurate tach in this truck?
If its pure speed you're after..... find a 2.76 or 2.94 chunk and put it in.
- quickgraffix
- City: stockton
hey john ..yes i think it off a little bit ..with the pedal floored i can barely pass a semi truck
[/quote]
[/quote]
Dana 8 3/4. When did Chrysler make those
[/quote]
- quickgraffix
- City: stockton
here's some pictures of the crankshaft numbers and the front where the flywheel connects ill get pics of the rear end today
I had a 360, aluminum intake, edilbrock afb, and headers. With np-435 and the 3.23 rear set in a 8.75. D-100. At close to 100 mph the truck would feel like it was ready to take off like an airplane.
Looks like it might have a pilot bushing in it already. If so, you have a find!quickgraffix wrote: ↑Thu Oct 29, 2020 2:21 pmhere's some pictures of the crankshaft numbers and the front where the flywheel connects ill get pics of the rear end today
Find out your axle gear ratio.quickgraffix wrote: ↑Thu Oct 29, 2020 12:40 pmhey john ..yes i think it off a little bit ..with the pedal floored i can barely pass a semi truck
- quickgraffix
- City: stockton
sweet now next question do i buy a clutch for the transmission or for the motor?
John ill know that answer next week i guy a rear end shop i do business with in livermore ca hes going to check it out for me
Barry is the man around here in that business.quickgraffix wrote: ↑Thu Oct 29, 2020 7:21 pmJohn ill know that answer next week i guy a rear end shop i do business with in livermore ca hes going to check it out for me
- quickgraffix
- City: stockton
Barry is the man for sure he said bring by my truck so he could check out my gearingWildergarten wrote: ↑Thu Oct 29, 2020 11:03 pmBarry is the man around here in that business.quickgraffix wrote: ↑Thu Oct 29, 2020 7:21 pmJohn ill know that answer next week i guy a rear end shop i do business with in livermore ca hes going to check it out for me
also if i hit pick n pull and decided to swap out my whole rear end what vehicle is the fastest and easiest swap
