3 speed on the tree shifter bushings
- City: Winter Park
While doing a steering box swap I had to loosen the steering column and noticed some slop in the linkage. Is there supposed to be a bushing at the bottom? I ended up removing the column to get a closer look.
Re: 3 speed on the tree shifter bushings
Yes, see attached. I have a complete working set up if interested.
- City: Winter Park
Speaking of the end with the end washer, (the U bolt looking bracket) mine has 2 pegs to keep the shaft centered, one is almost gone so thats where my slop is. Does yours have the 2 pegs?
Make a new tab with a welder, grinder and file.
- 67D100Pickup
- City: Noble
PM me and we can discuss.
