Help Finding 1969 D100 Clutch Adjustment Rod
GnomeSaiyan
City: Draper
State: UT
Post by GnomeSaiyan »
Hello,
I’m installing a fresh 318 in my ‘69 D100, but when I pulled out the original engine, I broke the looped end of the clutch adjustment fork. Now I can’t find one online or at major parts stores anywhere; if I had known that they were worth their weight in gold, I would have been a lot more careful.
Does anyone know where to find this specific rod? Even better if it comes in a kit, because I’ll need the rubber spacer/nut/return spring.
Alternatively, do other rods/kits work on the D100, such as A-body or B-body kits?
Thanks
ozzie
City: colorado springs
Re: Help Finding 1969 D100 Clutch Adjustment Rod
Post by ozzie »
I have the rod, and the adjusting nut. can't remember if the rubber spacer is with it. if you are interested in it, let me know, and I will check to see if the rubber is with it.
ozzie
