'64 D100 front u-joint question
Westfalia
City: Fullerton
Post by Westfalia »
I need a front u-joint for a '64 318 4 spd. equipped D100. This is the smaller one attached to the front slip yoke bolted to the transmission E-brake flange. PNs or links would be much appreciated.
Re: '64 D100 front u-joint question
Wow, member for 7 yrs and this is your first post - that's a new record!
The UJ will be the same as at the axle. I don't recall what the PN is, but NAPA should be able to get them easily, and likely other parts stores too.
