Transmission mount
Transmission mount
I need help, I have a 1969 d100 with 225 & manuel transmission. I need a transmission mount. Every parts place shows one, but it's the wrong one mine is flat and about one inch thick. All I can find are kinda round and bolt through a drop down cross member, my cross member is straight. I would appreciate any help,this truck has been my baby since Feb. 1995 passed down from my dad who got her in 1982.
- WD
- City: Rosemark
Re: Transmission mount
Look at other brand mounts. S10 and Danger Ranger 5 speeds used flat mounts, so did some Jeeps and 73-91 Chebbies
Seeing as you as showing signs of being an "interchange guru," I'm looking for rubber NP201 transfer case mounts.
- WD
- City: Rosemark
VPW and Kanter both used to have those...
Interchange guru? Just a cheapskate. Mopar stuff is expensive, GM not so much.
They're not in either current catalog. Nor are they made by promerican or Steele. I may just turn a mold and cast my own in polyurethane.
- WD
- City: Rosemark
$100.60 fir the complete set. 61-75 International. Travelallparts.com
Or just use generic shock or swaybar endlink bushings. GM stuff.
- WD
- City: Rosemark
Look for the t-case, not what it is mounted in.
Right case, wrong mount pad. I doubt those will take the torque from a BB Mopar dragging logs in low range.
I'd make them first. Amazon has good kits for two-part polyurethane elastomers in various durometers.
- classiclvr
- City: lititz
- State: PA
Flat and looks like a rubber brick on a piece of flat steal with 2 holes going up thru for trans and 2 down thru on ends for crossmember?
(or could be other way). I think I found mine by looking up a Dodge motorhome and even then its was NOS MOPAR and from Ebay. I have the part# at home for it somewhere.
May I suggest creating your own thread for what you're after.Wildergarten wrote: ↑Sun Sep 15, 2019 9:20 am
- swptln
- City: East Brookfield
- State: MA
Do a search on ePay, there about the only place you will find them. Most of the NOS stuff has been depleated.GMAN69 wrote: ↑Sun Sep 15, 2019 5:46 amI need help, I have a 1969 d100 with 225 & manuel transmission. I need a transmission mount. Every parts place shows one, but it's the wrong one mine is flat and about one inch thick. All I can find are kinda round and bolt through a drop down cross member, my cross member is straight. I would appreciate any help,this truck has been my baby since Feb. 1995 passed down from my dad who got her in 1982.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
- classiclvr
- City: lititz
- State: PA
This it? Same problem I had with my '71 with the 318 and 727 trans. 1972-78 Dodge motorhome rear trans mount. 8" overall, 4" center between inner holes and 7" center between outer holes. Replaces Mopar part# 3632984. Currently on ebay for $75.
