W200 4x4 gearing
- City: Hollister
W200 4x4 gearing
Hello guys, got questions for 71 dodge crewcab w200 (8 lug) 4x4 gearing, at the moment I have 4.88’s. I got a slant 6 that is going on a turbo upgrade. What gears were available for a Dana 44HD and Dana 60? 4.10 and 4.88??? Was 3.55 and option for these 8 lugs? I’m not planning on towing, just mild hauling every now and then. I’d like to get 3.55’s if it is even an option.
Re: W200 4x4 gearing
The 3.54 ratio was available on Sweptline W100s [pre-'69] and W200s.magnumforce1987 wrote: ↑Sat May 18, 2019 9:30 amHello guys, got questions for 71 dodge crewcab w200 (8 lug) 4x4 gearing, at the moment I have 4.88’s. I got a slant 6 that is going on a turbo upgrade. What gears were available for a Dana 44HD and Dana 60? 4.10 and 4.88??? Was 3.55 and option for these 8 lugs? I’m not planning on towing, just mild hauling every now and then. I’d like to get 3.55’s if it is even an option.
I have a '68 W100 with the Dana 60 / Dana 44F with 3.54s.
- City: Hollister
Is the ring and pinion interchangeable from a 1/2 (5 lug) ton to 3/4 (8 lug)?Hobcobble wrote: ↑Sat May 18, 2019 5:08 pmThe 3.54 ratio was available on Sweptline W100s [pre-'69] and W200s.magnumforce1987 wrote: ↑Sat May 18, 2019 9:30 amHello guys, got questions for 71 dodge crewcab w200 (8 lug) 4x4 gearing, at the moment I have 4.88’s. I got a slant 6 that is going on a turbo upgrade. What gears were available for a Dana 44HD and Dana 60? 4.10 and 4.88??? Was 3.55 and option for these 8 lugs? I’m not planning on towing, just mild hauling every now and then. I’d like to get 3.55’s if it is even an option.
The pre 69 W100s did not use a 5 lug axle. They used the same 8 lug axles as the 3/4 ton trucks.magnumforce1987 wrote: ↑Sat May 18, 2019 7:13 pmIs the ring and pinion interchangeable from a 1/2 (5 lug) ton to 3/4 (8 lug)?Hobcobble wrote: ↑Sat May 18, 2019 5:08 pmThe 3.54 ratio was available on Sweptline W100s [pre-'69] and W200s.magnumforce1987 wrote: ↑Sat May 18, 2019 9:30 amHello guys, got questions for 71 dodge crewcab w200 (8 lug) 4x4 gearing, at the moment I have 4.88’s. I got a slant 6 that is going on a turbo upgrade. What gears were available for a Dana 44HD and Dana 60? 4.10 and 4.88??? Was 3.55 and option for these 8 lugs? I’m not planning on towing, just mild hauling every now and then. I’d like to get 3.55’s if it is even an option.
Seems to me that the final drive ratio you want is also dependent upon the size of the tires you plan, but it looks like you are trying to do as tall as possible. For mileage?magnumforce1987 wrote: ↑Sat May 18, 2019 9:30 amHello guys, got questions for 71 dodge crewcab w200 (8 lug) 4x4 gearing, at the moment I have 4.88’s. I got a slant 6 that is going on a turbo upgrade. What gears were available for a Dana 44HD and Dana 60? 4.10 and 4.88??? Was 3.55 and option for these 8 lugs? I’m not planning on towing, just mild hauling every now and then. I’d like to get 3.55’s if it is even an option.
Never thought of a turbo on a /6, but it would seem that in terms of room, the engine is ideal for such as long as you've upgraded the head with hard seats and sodium filled or stellite valves and plan an intercooler with a decent waste gate. Keep us updated on this as it will be interesting to see what combination of bottom -end torque and mileage you get out of it with tall gearing.
- City: Hollister
I’m planning on running 35’s. I’d do 4.10s if need be. I just don’t want to be roaring down the highway at 55,60,70 mph.Wildergarten wrote: ↑Sun May 19, 2019 12:49 pmSeems to me that the final drive ratio you want is also dependent upon the size of the tires you plan, but it looks like you are trying to do as tall as possible. For mileage?magnumforce1987 wrote: ↑Sat May 18, 2019 9:30 amHello guys, got questions for 71 dodge crewcab w200 (8 lug) 4x4 gearing, at the moment I have 4.88’s. I got a slant 6 that is going on a turbo upgrade. What gears were available for a Dana 44HD and Dana 60? 4.10 and 4.88??? Was 3.55 and option for these 8 lugs? I’m not planning on towing, just mild hauling every now and then. I’d like to get 3.55’s if it is even an option.
Around here, that ain't roaring! 85-100 for the majority of trafficmagnumforce1987 wrote: ↑Sun May 19, 2019 4:30 pm.........I just don’t want to be roaring down the highway at 55,60,70 mph.
- City: Hollister
With 4.88 gears at 55-65 RPMS will be way high? No?PwrWgnDrvr wrote: ↑Sun May 19, 2019 5:17 pmAround here, that ain't roaring! 85-100 for the majority of trafficmagnumforce1987 wrote: ↑Sun May 19, 2019 4:30 pm.........I just don’t want to be roaring down the highway at 55,60,70 mph.
4.88 and 35s will be fine a 55. Any faster, not so much.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
4.88s and 35s can go 65 easy. there are calculators online for rpms. 4.10 is as tall as i would ever go with a tire that large and a slant 6. I personlly like the 4.88s. very hilly around here so they work great. If I lived in flatlands I would do the 4.10s. 3.55s are for broncos stuck in the mud. ;/)
- PowerMan
- City: Auburn
I would suggest at least 4.10's with 35's and a slant 6. 4th gear direct at 65 with 35" tires and 4.10 ratio = 2550 RPM.
Im not up to par on my Slant 6 knowledge but I know it is way different than the cummins in my truck. I run 35" tires with .73 overdrive and 3.54 gearing and at 70 it is roughly 1850 RPM (according to my tach). Check out https://crawlpedia.com/rpm_gear_calculator.htm for some quick drivetrain calculations. I don't know what the power curve of a Slant 6 looks like especially with a turbo.
Do you have the crew cab north of town on 156? Missed out on the Power Wagon Rally a few weeks ago at Hollister Hills.
- swptln
- City: East Brookfield
- State: MA
I agree, 4.10 is as low as I would go if your running tall tires. If your running an automatic, you could go to 3.91's.
With a stick, I'd stay with 4.88's or 4.10's depending on tires size. I ran 4.88's and 34's and had no trouble running 65-70, she would cruise all day long at 60 mph on the highway was perfect......but if I wanted to go and pass, she would go to 65-70 easily.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
