I'm rebuilding the BBS from my '61, and having a lot of fun doing so. The carb kit came from Rock Auto, and it's been great.
Worried, though, that I'm missing a part. I found reference to putting a spring clip on the pump plunger. Now, to me, it doesn't seem like there's a place one can go, and there was no spring clip when I disassembled it.
Am I missing something?
Carter BBS - Spring Clip on Pump Plunger
1961 Dodge D-100
Alberta, Canada
Alberta, Canada
Re: Carter BBS - Spring Clip on Pump Plunger
I would put it back the same way you took it apart.( in reverse of course ) . Many times those instructions cover a broad range of carbs.
Thank you kindly. That kit has 3 times the parts I need!
The washer under the piston was missing when I took it apart, so I put one in, but other than that, we're good!
Visiting Texas next week, great to know there's swell folks like yourself there!
By the way, is the 383 in your '68 original?
1961 Dodge D-100
Alberta, Canada
Alberta, Canada
Thanks for the kind words. Yes the 383 is original in the '68 . (I sold the '68 to a friend a while ago )Snowdog wrote: ↑Thu Mar 21, 2019 8:59 pmThank you kindly. That kit has 3 times the parts I need!
- Grodr625
- City: Seattle
I believe the bbs has a similar plunger to the bbd. This is what I had and my kit did not include a replacement clip nor spring.
1964 S400 318 poly 4 speed - Linda aka Big Booty Judy
Previous swepties:
1968 D100 318, Hardworking Herbert
1966 D100 318 poly 4 speed - Ginger/Sancha/CrucesCruiser
https://stavisaves.wordpress.com/
Previous swepties:
