Big block ID
Big block ID
where are the 361 and 413 truck engines stamped? I think my engine might be a 413 and not a 361
Re: Big block ID
The 361 is stamped on the flat area that has the distributor hole in it.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
Re: Big block ID
If memory serves it would be 36T.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
Re: Big block ID
I also think all 413 truck engines were 4V carbs and 361 truck engines were 2V carbs.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
Re: Big block ID
tha nks for replies. I will look tomorrow. the 413 did also come with a 2 barrel. 4 barrel only an option. might have been standard on very large trucks
Re: Big block ID
I had a 361 with a 4bbl manifold on it. Had been swapped into a 66 D300.
Re: Big block ID
do I need to remove the dist hold down to see the stamping?
- pwadventurer
Re: Big block ID
location should be to the left of distributor.
Re: Big block ID
ok thanks . I guess I have to pull alternator mounting bracket.
