I see a lot of discussion about putting in a 440 where a 318 sat...bell housings comes up a lot. Couldn't the 440's bell stay with the motor and just bolt to the 727? Am I looking at this wrong? I think a lot of folks just try to mount the 318 bell to the 440 right instead of other way round.
Kupa
engine swap and bellhousing
- City: Clovis
Re: engine swap and bellhousing
No bell house for a 727 right? Bell housings are for the clutch.
kupatalks67 wrote: ↑Sat Jun 16, 2018 8:04 pmI see a lot of discussion about putting in a 440 where a 318 sat...bell housings comes up a lot. Couldn't the 440's bell stay with the motor and just bolt to the 727? Am I looking at this wrong? I think a lot of folks just try to mount the 318 bell to the 440 right instead of other way round.
Kupa
No matter how you look at it, A 440 or BB Engine will not bolt to a SB (Small Block) transmission/bell housing .
The transmission has a built in bell housing as part of the case. You may be able to cut and weld a new bell housing on but it may not be worth doing.
- City: Clovis
Thanks for showing me the error in my ways....just googled a picture of the 727.
kupatalks67 wrote: ↑Sun Jun 17, 2018 7:22 pmThanks for showing me the error in my ways....just googled a picture of the 727.
They're is a company that sells bell housings that bolt to transmission using pump bolts. The existing bell housing has to be cut off just even with front edge of pump. Don't remember company name.
Ultra Bell.dodgeboykim wrote: ↑Sun Jun 17, 2018 11:03 pm
https://www.jegs.com/i/JW-Performance/5 ... 7/10002/-1
'63 D100
- City: strathmore
just a bb 727 will do nicely , thinking maybe a 383 crossmember for the tranny and bobs your uncle
