Auto Trans
Posted: Thu Jan 04, 2018 7:11 pm
Looking into possibly pulling the three-speed standard trans and replacing it with an automatic in my 61 D100 225 /6. Any suggestions?
'61-'71 Dodge Sweptline Truck Online Community
https://www.sweptline.org/forums/
The '65 dart 904 is also cable shifted (PITA). I would look for a later model 727. ( and remember all the stuff you will need: spanner, cross member, shifter, drive shaft, radiator,and other. )pismopowerwagon wrote:I have a slanty 904 automatic if you go that route and need one. Out of a `65 Dart so it has flange output.
Yes, PITA.......if you were to make the change, it would be cool to find a poly/727/push button unit to keep it period correct. a lot of options for the poly these days.61stepside wrote:The old three on the tree keeps looking better. Didn't realize how much a pain in the @#% it would be.
Txas2step wrote:Yes, PITA.......if you were to make the change, it would be cool to find a poly/727/push button unit to keep it period correct. a lot of options for the poly these days.61stepside wrote:The old three on the tree keeps looking better. Didn't realize how much a pain in the @#% it would be.
And, the damn 8 bolts have nuts on them that are a ROYAL PITA to get apart!soopernaut wrote:The stock auto for a 61 was a predicessor to the A727 called the A488 and it was cast iron. 1961 and prior engines used an 8 bolt crankshaft and flywheel.
