Page 2 of 2
Re: Fast Idle issue
Posted: Wed Dec 13, 2017 7:40 pm
by MadMC63
Thinking about that sticking problem you might feel the end closest to the carb to see if you can feel a burr on it at the opening. If you do you could file it off. After many years of use it is posible for the inside of that end to mushroom a little. Just a thought.
Re: Fast Idle issue
Posted: Fri Dec 15, 2017 12:06 pm
by coelcanth
don't know if it's helpful,
but here's a couple shots that show the upper throttle and kickdown linkages on my 318 with 2bbl
which i'm pretty certain is the original V8 setup
Re: Fast Idle issue
Posted: Mon Dec 18, 2017 2:34 pm
by fosterfarm
coelcanth wrote:don't know if it's helpful,
Thank you - it is helpful. This is an auto trans yes?
Re: Fast Idle issue
Posted: Mon Dec 18, 2017 2:42 pm
by MadMC63
Yes.
Re: Fast Idle issue
Posted: Mon Dec 18, 2017 4:42 pm
by thehemikid
This doesn't help your sticky or short stroke linkage problem but will cause havoc with idle.
Is this vac port still uncapped?
Re: Fast Idle issue
Posted: Mon Dec 18, 2017 6:04 pm
by fosterfarm
thehemikid wrote:This doesn't help your sticky or short stroke linkage problem but will cause havoc with idle.
Nope - was just unplugged while I was cleaning.
So I sprayed a bunch of carb cleaner all over and inside and it seems to have fixed the problem. I also have a rod linkage coming later this week and am going to try to attach it to ensure WOT happens when pedal is fully pressed (only engages about 50% currently).
