1967 Dart 273
Posted: Wed Nov 29, 2017 5:16 pm
by Caleray
On Thanksgiving morning I acquired a 273 out of a 1967 Dodge Dart for $400. The engine only has 36,000 miles. My question is do I have to change the oil pan to fit in my 1963 D200?
Re: 1967 Dart 273
Posted: Wed Nov 29, 2017 6:41 pm
by Txas2step
You should be OK, being a D200. Just watch the clearance to the axle. What engine are you replacing? Is the 273 a 2 barrel or the 4 barrel ? It's a great little motor for a Dart....not much power in a D200. I just finished building one that was a 2 barrel 30K mile from a 1965 dart. added a 4 barrel and Isky cam.
Looking for a place to stuff it.
Note: if you can find a LA small block front sump pan and pick-up...a little extra insurance.
Re: 1967 Dart 273
Posted: Wed Nov 29, 2017 7:19 pm
by Caleray
I'm replacing a 225 slant 6. The 273 was a 2 barrel but it now has a Edelbrock "STREETMASTER" aluminum 4 barrel intake from the early 1980's. What size cam did you put in yours?
Re: 1967 Dart 273
Posted: Wed Nov 29, 2017 8:46 pm
by PwrWgnDrvr
It will not have hardened valve seats to be compatible with unleaded gas. Do the valve job now, or do it in the near future.
Re: 1967 Dart 273
Posted: Wed Nov 29, 2017 9:13 pm
by Txas2step
Caleray wrote:I'm replacing a 225 slant 6. The 273 was a 2 barrel but it now has a Edelbrock "STREETMASTER" aluminum 4 barrel intake from the early 1980's. What size cam did you put in yours?
I used the Isky E4 # 390144 fairly mild but gives the little motor some extra pep. You can use your /6 motor mounts but you will need to source some truck small block motor brackets. Terry is right about the valve seats....I had them changed when I rebuilt the motor. Do you have solid or hydro. lifters. I know they changed from solid but don't recall which year. The e4 cam works with both.
Note: just checked hrdro. lifters started in '68.
Re: 1967 Dart 273
Posted: Thu Nov 30, 2017 6:46 am
by Caleray
Do the small block motor brackets have to be from a Sweptline? Can they be from a 1972 or newer pick-up?
Re: 1967 Dart 273
Posted: Thu Nov 30, 2017 2:51 pm
by dodgeboykim
Re: 1967 Dart 273
Posted: Thu Nov 30, 2017 5:11 pm
by Caleray
I don't have any engine brackets at all right now. I'm just trying to figure out what kind of truck I need to scavenge some from before I start looking.
Re: 1967 Dart 273
Posted: Fri Dec 01, 2017 2:21 pm
by Txas2step
Caleray wrote:I don't have any engine brackets at all right now. I'm just trying to figure out what kind of truck I need to scavenge some from before I start looking.
1961-71 dodge truck small block for sure.
