I have a 67 318 harmonic balancer
Heward58
City: Woodruff
Post by Heward58 »
I have a 67 318 that has a normal front pulls no harmonic damper I have rebuilt the engine and want to have the protection of the damper what have you guys used
MadMC63
City: Rome
Re: I have a 67 318 harmonic balancer
Post by MadMC63 »
I've got a spare balancer from a 70 318 truck (steel crank). Don't know if its what you want or need.
1971 Dodge D100
Heward58
City: Woodruff
Post by Heward58 »
I’m not shure because it didn’t have one so if I add one I may meet to change my pully
The pulley u have will not work with a harmonic balancer. U also need one that is correctly indexed for the timing mark on your engine.
Heward58
City: Woodruff
Post by Heward58 »
The timing cover doesn't have any marks on it i under stand that I will need a different pully do you know of any combinations that will line up with the original pulley
Heward58
City: Woodruff
Post by Heward58 »
The truck belonged to my grandfather naught in new and it's never left the family original engine first time it's even been out of the truck I'm just wanting the damper as insurance because I have a boatload of money in the engine and I want to keep numbers matching
should last forever without one. I have had polys with and without and both ran very smooth. mopar factory balancing was quite good
