Can the rubber insulator engine mounts (1970 small block) be replaced without removing the all steel engine brackets?
Thanks,jim
rubber engine mounts
- City: Elbert County
Re: rubber engine mounts
Just detach the Radiator hoses and remove the Distributor cap and you will be able to jack it up high enough to replace. Just did it on my 318 a month ago.
1969 D100 LWB 318 np435
Thanks guys.
jim
jim
