Oil pan help
Oil pan help
So I have a 70 d200 with a 383. That motor isn't matching numbers but the truck origanily came with one. The number on the oil pan is 187. My service manual says the motor should hold 7 quarts, but the dipstick says it's full at 4. Do I have the correct oil pan?
Re: Oil pan help
Is this a front sump pan?
Re: Oil pan help
Do u have the correct dipstick?
Re: Oil pan help
Yes it's a front sump, as far as the dip stick goes I'm not sure either the truck was kind of jacked up when I got it so there's a lot of unknowns as far as what's original. This is my first car so I don't have a enough knowledge to know
Re: Oil pan help
Google pictures of the engine and compare pans. Typically trucks have front or rear sumps where as cars have a center sump. Not a 100% accurate philosophy but a good place to start. Dipsticks are a pretty common loss dipstick tubes not so much.
1971 Dodge D100
Re: Oil pan help
This era of truck always had a front sump pan from the factory.
How do you know the 383 isn't original to the truck? They didn't have the VIN on them. In trucks they were used 67-71, so not many years.
Re: Oil pan help
I know it's not original because my truck was built in September of 69, the motor wasn't built til March of 70. On the bottom of the block the first part of the vin was stamped on, and that doesn't match the trucks vinsoopernaut wrote:This era of truck always had a front sump pan from the factory.
