About every 10th time or so; when I go to start my '68 W-300 with 318 engine, I get a grinding noise and the engine does not turn over. It will do this once, twice maybe 3 times then start as normal. All the other times I get a normal start - no noise.
I figured the flywheel had a broken or damaged tooth so I removed the clutch cover and checked. The teeth on the flywheel are fine. Next I removed the starter, thinking the teeth on the starter may be bad; however they were fine. Next maybe the solenoid was hanging up so I ran the starter about 50 times on the bench and the starter and solenoid worked fine.
Any ideas as to what is causing the intermittent grinding noise??
Starter grinding noise
Re: Starter grinding noise
Bad bendix drive on the starter
