Carb problem?
Posted: Thu Jul 27, 2017 4:55 pm
by Beals
68 D100 383. 4 barrel from 68 Newport. Manifolds from 440 motor home. Thrush glass packs. Carter AVS. Had to prime carb, when running burned paint off left muffler. Bad carb?
Re: Carb problem?
Posted: Thu Jul 27, 2017 7:15 pm
by PwrWgnDrvr
Why is there paint on a muffler?
Re: Carb problem?
Posted: Thu Jul 27, 2017 7:23 pm
by Beals
The glass packs i bought were red. Maybe some type paint or coating. Passenger side didn't burn.
Re: Carb problem?
Posted: Thu Jul 27, 2017 8:15 pm
by 712edf
The other side will eventually burn too.
If exhaust is cooler on one bank it could be a sign of dead cylinder.
Re: Carb problem?
Posted: Thu Jul 27, 2017 8:33 pm
by Beals
Will check for dead cylinder. Maybe check compression. The motor sat for a long time. Will check easy stuff first( plugs, wires, ) thanks
Re: Carb problem?
Posted: Thu Jul 27, 2017 8:35 pm
by PwrWgnDrvr
As Bucky said, the side that DOESN"T burn is the problem.
Re: Carb problem?
Posted: Fri Jul 28, 2017 6:01 pm
by 712edf
Of course when I mentioned dead cylinder, I didn't take into account how the engine ran. You didn't specify if it had a miss or not.
Does it run poorly?
Re: Carb problem?
Posted: Fri Jul 28, 2017 9:52 pm
by Beals
Wife said it was missing, nephew said it ran good. The one side didn't get hot until recently. Rings are probably dry from sitting. Will pull the. Plugs and put diesel in the cylinders.
