Trans leak
Beals
City: eagle point
Trans leak
Post by Beals »
When to check fluid level, cold or hot? It was a pint low when cold. Leaked like crazy. When it warmed up, stopped leaking and was full. Expansion of fluid?
If it were easy, everyone would do it.
Re: Trans leak
Auto trans?
Right on the dipstick is printed: "Check when hot, idling in neutral"
Beals
City: eagle point
Re: Trans leak
Post by Beals »
Thanks. Read that, but it was cold and didn't know how much to put in. It didn't shift after added fluid when changed filter. Had sat for 10-15 years.
Re: Trans leak
If your kick down lever is not adjusted properly that can cause converter to drain back into transmission when sitting and leak out wherever it can. Just an idea.
Andy
Beals
City: eagle point
Re: Trans leak
Post by Beals »
Will check it out. i thought it was just low. Would not even engage before i added fluid.
Beals
City: eagle point
Re: Trans leak
Post by Beals »
Linkage was way out of adjustment. Adjusted it, and i think the leak stopped. So much fluid everywhere.
marklein
City: Red Deer
Re: Trans leak
Post by marklein »
Linkage adjustment won't cause it to leak. Seals get old, they then leak from evrywhere. If a torqueflite drains back, the pump gears or pump bushing may have excess clearance, or valves in the valve body may have some wear as well. Check it hot, idling in neutral, if it is overfull, it will appear to leak out the front, as that is where the breather is. In my shop, I use good grade silicone to seal the pan these days, those pans weren't designed for a gasket other than cork, and imho a cork gasket is a waste of energy. At full throttle, the trans tv linkage should be all the way to the back of travel at the trans, with a small amount of free play.
