Rear Driveshaft fit
- City: Elbert County
Rear Driveshaft fit
New to the forum! Picked up a 69 d100. I looked at a few when purchasing, so I'm not yet an expert. One thing on my new truck that doesn't look right to me is the gap on the spline shaft to the rear driveshaft. See attached. Is this pretty normal or should I be looking closer at something else that is wrong. Truck is in remarkable shape and drives etc exceptionally well. It is going to be a driver for my wife.
- Attachments
- Screen Shot 2017-07-18 at 8.14.04 AM.png (115.01 KiB) Viewed 319 times
1969 D100 LWB 318 np435
Re: Rear Driveshaft fit
That slip yoke slides back and forth as the truck goes over bumps, dips and the suspension flexes. Totally normal.
Thanks! All of my other trucks have been SWB so that yoke is new to me! Thanks for the help!PwrWgnDrvr wrote:That slip yoke slides back and forth as the truck goes over bumps, dips and the suspension flexes. Totally normal.
Yes, that's good as is. You need a bit of run out, as Terry mentioned.
