318 engine stalls
slz
City: tucson
318 engine stalls
Post by slz »
I have a 68 with a 4 speed tranny.
When I brake aggressively the engine dies.
Tried disconnecting and plugging power brake booster, but it did not help.
Any suggestions? thanks
Re: 318 engine stalls
Do u slam the clutch pedal to the floor at the same time as u hit the brake pedal?
slz
City: tucson
Post by slz »
Even when I put it in neutral, release the clutch and then brake, it dies.
Is the clutch operating? flywheel not stuck to disc?
Check for other vacuum leaks?
MadMC63
City: Rome
Post by MadMC63 »
Is the engine idle speed set high enough to begin with?
1971 Dodge D100
SoleSurvivor
City: Torrance
Post by SoleSurvivor »
slz wrote:I have a 68 with a 4 speed tranny.
Fuel pressure is dropping or float level needs adjustment(not enough fuel in the float bowls to keep fuel from flowing).
Raise idle speed to 1200 and then test your hard braking. If the engine sputters but doesn't stall adjust floats and then back off your idle.
1962 Fargo Torrance, CA
slz
City: tucson
Post by slz »
Thanks for all the advice.
It was the float set too low.
It runs and stops good now.
SoleSurvivor
City: Torrance
slz wrote:Thanks for all the advice.
Glad your truck is running well.
