Carb replacement
Posted: Thu May 11, 2017 8:52 pm
by Randy
I have a stromberg ww 2 barrel on my 65 318 i have tried to rebuild it but think it's shot . Is there a direct new replacement out there? Would like not to do alot of mods and would like to use the original air cleaner if possible any help?
Re: Carb replacement
Posted: Fri May 12, 2017 5:51 am
by Txas2step
Carter BBD. Bud Tharp may have a good one.
Posted: Fri May 12, 2017 6:36 am
by wally426ci
Thorp aka Powerwagon54
Posted: Fri May 12, 2017 9:32 am
by 12Valve
I second the Carter BBD they are a dime a dozen, I have three on hand as spare parts, and one that I am slowly converting to be a blow though turbo setup. Be leery of the shaft bushings as they will cause a vacuum leak, or boost leak if too badly worn.
Posted: Fri May 12, 2017 1:21 pm
by Randy
Thanks for the info, I'll have give that a try.
