late model la swap
swampfoxjr
City: parma
State: MI
late model la swap
Post by swampfoxjr »
hey guys needs some help, my 68 had no motor and trans when i bought. ive got a donor 318/727 out of an 84 w250. ive got new rubber mounts for the 68 but it seems both the block mounts need to be longer? if i mount one or the other the motor is off center in the frame. the 68 originally had a 318. any ideas? lengthen both the block mounts? it almost looks like it would drop right in if i moved the holes in the block mounts up. the chassis mounts are the same as well as the block mounts. just need to know how long they need to go, if its a straight out or if they need to be offset?
1968 lwb 2wd
Re: late model la swap
What block engine mounts are you using. The 84 ones. Not sure what if any height/length difference the 84 to 68 ones have. Post a picture with measurements. The 68 isolaters are different for sure.
swampfoxjr
City: parma
State: MI
ill get pictures tonight. im using the 84 block mounts with the new 68 isolators
1968 lwb 2wd
coelcanth
City: Brooklyn
State: NY
Post by coelcanth »
i don't have any detailed photos,
but here's a few shots from my project where you can catch a glimpse of the LA318 motor mount brackets:
there's just a single slotted hole for the isolator stud
and here is a generic photo of the correct motor mount/rubber isolator:
Here's a shot of the right side engine bracket.
You can see the rubber insulator that Coelcanth
posted above.
John :study
swampfoxjr
City: parma
State: MI
thats perfect they both look to be longer than mine. looks like ill be fabricating some. can you get me a measurement from the bolt hole on the block to the base of the bracket where the mount sits?
do these trucks require front sump oil pans??
1968 lwb 2wd
MadMC63
City: Rome
Post by MadMC63 »
As long as the sump clears the front suspension it probably doesn't matter. It was designed to be a truck and with that in mind a front sump pan. Racing and crawling apps might change the decision making paradigm.
1971 Dodge D100
swampfoxjr
City: parma
State: MI
ok. the motor going in has a rear sump, it will get lowered so ill just be sure to keep an eye on it. eventually the truck will be getting a newer hemi but im ready to get it on the road for now and out of the side yard lol
1968 lwb 2wd
