This is 1 do 2 problems I have not tracked down yet and getting tired of it.
I am thinking that the fuel line under hood gets hot and pushes fuel into the carb which results in flooding. If my theory is correct, has anyone successfully dealt with this? Any other ideas?
Floods after long drive and sitting for 30mins
Re: Floods after long drive and sitting for 30mins
Not possible. Full float bowl closes the needle valve and no more fuel can enter the carb long before it could overflow and flood the engine. Furthermore, any pressure in the fuel line from heat would push the fuel backward into the tank as well as toward the engine, and no way the fuel would expand enough to flood an engine.
Sounds like a float bowl leaking into the manifold after shutdown, or maybe a choke not fully open when hot.
Thanks terry, do you have an idea on how I can dig further into a possible float bowl issue?
I was also wondering if fuel boiling with heat under hood would bubble it into the manifold.... it was definitely flooded after I started it again yesterday.
Carter 2 barrel on my 68 100 - don't have the model number on hand but pretty sure it is the original....
- franktiregod
- City: Covington
- State: GA
Have you rebuilt it? Sounds like the float is sticking if I am reading this right.
6-16-1986 12-5-2008
6-16-1986 12-5-2008
It's been about 8 years - I may pull it apart soon
Has your state gone to "oxygenated" winter fuel blend? Here in CA the I have that problem with most carburated vehicles with winter blend fuel.
