Carb linkage-slant6 to la318 swap
spoilerecw
City: Eakly
Post by spoilerecw »
Going to be doing a la318 swap into my 62 d100. Anybody know if the my old slant 6 throttle lever underhood will work on the 318? Also anybody have a 318 3 core radiator and shroud they want to sell? Or what suppliers radiator will work without hacking up core support? Thanks.
Brandon
Re: Carb linkage-slant6 to la318 swap
Part that goes through the firewall should be the same as v8. Part to carb. Nope.
:goodpost As Kim says. Plus, if your truck has an automatic
tranny, the kick-down linkage is different as well.
spoilerecw
City: Eakly
Thanks for the info guys. Yes the throttle rod is what I was wondering about-part to carb. My truck was a 3 on the tree also. Anybody have any throttle rods for a la318. 3 core radiator & shroud? Thanks
Brandon
Lobster
City: Portland
Post by Lobster »
I have the rod from my 64 318 truck. I just switched to a cable style throttle when I went to 4 bbl. This should work for your truck. Send me a pm if you are interested.
Barnaby
