Hello all. I know very little about drivelines, but will be taking a class this semester at the local community college that will hopefully have some decent time spent in the shop.
My parts truck has what I am guessing is a Dana 44 with disc brakes and a power steering setup.
I found the following markings on it looking at it from the front:
44-8F (lower right)
2 over 620121 R (lower left)
From rear of differential on upper left: 023 (?)
And the rear end has the following numbers:
From front
340 3 (Bottom Center)
4032374 (Upper Left)
23258 (Lower Right)
6 (Upper Right)
My questions:
1. Is the Dana 44-8F a decent front axle?
2. Would it be something I could possibly swap into my '68 W200 Crew Cab without much fabrication needed? Adding disc brakes and power steering to my rig would be nice.
3. Any ID help on the rear end using the numbers and pic above?
Thanks in advance for the guidance and info!
Possible Axle Swap?
- PowerMan
- City: Auburn
Re: Possible Axle Swap?
1. The Dana 44-3f is the same axle used since the late 50s in the W100 and W200 trucks that I have seen. There are different versions. They are good axles.
(57?-58)- large six lug pattern, closed knuckle, drum brake
(59-68)- Standard 8 on 6.5" lug pattern, closed knuckle, drum brake
(69-71) W100- 5 on 5.5" lug pattern closed knuckle, drum brake
(69-71) W200- 8 on 6.5" lug pattern, closed knuckle, drum brake
Newer model Dana 44s are open knuckle. Early versions still had drum brakes but they soon switched to disk brakes in the early/mid 70s. Caster angle does change after 71 which is something to consider if using a 72 and up front axle.
2. I'm a fan of the 8 lug axles mainly for wheel choice but that is up to you. You can easily swap the axles as the leaf spring perch width is the same. I do not know if all the Dodge Dana 44 front axles are the same overall width (wheel mounting surface to wheel mounting surface) but they are close. What year is your parts truck?
As for power steering conversions you will have to decide what type of power steering method (power steering gear box vs factory style power assist vs custom fab power steering gear box).
3. That rear axle looks like a 9.25" chrysler.
- Brudog
- City: Richardsville
- State: VA
PowerMan - Appreciate the response.PowerMan wrote:1. The Dana 44-3f is the same axle used since the late 50s in the W100 and W200 trucks that I have seen. There are different versions. They are good axles.
The parts truck has a chassis from the early eighties I believe and the cab is a '68.
Here is a pic of the power steering on it which I am guessing is factory style power assist:
Thank you.
To each their own.... but I wouldn't touch the current axles past
replacing brakes, lines, u-joints, etc..
- swptln
- City: East Brookfield
- State: MA
That is 72-up Saginaw power steering box, not power assist. One thing not mentioned is an original 68 front axle is a rear steer axle, the later ones like in that picture are front steer. So, swapping axles is not a direct swap, you will need a custom drag-link between your box and knuckle steering arm to make it work.Brudog wrote:PowerMan - Appreciate the response.PowerMan wrote:1. The Dana 44-3f is the same axle used since the late 50s in the W100 and W200 trucks that I have seen. There are different versions. They are good axles.
Thank you.
If your swapping the one in the picture then it will go right in with that power box.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
