Three on tree to floor shift
- City: 19067
- State: PA
Ok so I got a lot of info on converting my truck to a five speed, but I am also considering doing a floor shift conversion for the three speed. Does anyone know of a good kit I can use to make this happen? Also might want a different rear so my 318 doesn't scream so much on the highway. Any help would be greatly appreciated
Re: Three on tree to floor shift
Probably most any conversion kit you'd find at Summit or Jegs would suffice. As for the gears, whatPunisherD100 wrote:Ok so I got a lot of info on converting my truck to a five speed, but I am also considering doing a floor shift conversion for the three speed. Does anyone know of a good kit I can use to make this happen? Also might want a different rear so my 318 doesn't scream so much on the highway. Any help would be greatly appreciated
are you currently running? .... 3.91s? If you're not hauling heavy loads or towing, look into some 3.23s
or even 2.94s.
- my5thmopar
- City: Columbia
If you stick with the 3-on-the-tree...why change it. I rebuilt mine with new bushings. Shifts like new! Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
- hobo
- City: Alameda
Not to hijack, but is there a rebuild kit available for the three on the tree shifter?
1967 D-100, /6, 3 on the tree
- my5thmopar
- City: Columbia
Not that I could find. Somebody else may know. I used Steele Rubber 32-0342-24 for the grommets. I think I had to sand them down a little. The spring washers for the tree and linkage arm washers came from Ace. I had to drill out the washers since the arms were worn. Craighobo wrote:Not to hijack, but is there a rebuild kit available for the three on the tree shifter?
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
