What should the oil pressure gauge read for a 360? When I start my 73truck the gauge reads between 20-40. It has varied from day to day and the ambient temp has been the same. After warm up I see a drop to under 20 while driving and just above 0 at idle @800rpm.
Motor does not seem to be showing any issues and oil and filter were changed a month ago by the PO. Dipstick shows clean oil. Ar the readings I see normal? Do I possibly have a bad sender ?
TIA
Oil pressure in a 360
- City: Madison
- State: MS
Re: Oil pressure in a 360
Several things to consider here. Most obvious is an old engine with lots of clearance. Perhaps the PO used an oil that's to thin i.e. 5W30 or worse. Could be as simple as a less that accurate gauge.
1971 Dodge D100
- marklein
- City: Red Deer
Put a master gauge on it to eliminate gauge errors. That will give you piece of mind, either your engine is tired or you have gauge problems. My 360 was built with tolerances on the loose end, and 10w40 gives me about a 10 psi jump in oil pressure.
- City: Madison
- State: MS
I'll try replacing the sender. Any tips on easily getting to it? Being low and behind the Dizy it looks like you have to remove it to get to the sender. Then not much room to work still!
WhiteSpyder wrote:I'll try replacing the sender. Any tips on easily getting to it? Being low and behind the Dizy it looks like you have to remove it to get to the sender. Then not much room to work still!
Use a stubby open end wrench. Lay blankets over motor and get comfy, Then remove it. Should be able to do it without dizzy remove-all but if needed do so. Put a rag in dizzy hole so bad things don't fall in.
- City: Madison
- State: MS
Good to know, thanks.
dodgeboykim wrote:WhiteSpyder wrote:I'll try replacing the sender. Any tips on easily getting to it? Being low and behind the Dizy it looks like you have to remove it to get to the sender. Then not much room to work still!
You should still screw a mechanical gauge into block to confirm what pressure is. I have an old oil pressure gauge on a long grease gun flexible hose. Makes it easy to screw into block and is correct 1/4 NPT thread.
