Slant 6 to 318LA
spoilerecw
City: Eakly
Slant 6 to 318LA
Post by spoilerecw »
Hey guys was curious about what all is involved to swap a 318la auto into place of a slant 6 three on the tree into my 62 d100? Thinking about buying a running early 80s long bed for the donor drivetrain. Are the engine stands to frame different? Will the oil pan clear? Etc, etc? Thanks for your time.
Brandon
Re: Slant 6 to 318LA
spoilerecw wrote:Hey guys was curious about what all is involved to swap a 318la auto into place of a slant 6 three on the tree into my 62 d100? Thinking about buying a running early 80s long bed for the donor drivetrain. Are the engine stands to frame different? Will the oil pan clear? Etc, etc? Thanks for your time.
Brandon
You'll need to remove the hydraulic bell housing frame cross member.
You'll need to find the proper '61-'68 auto tranny cross member/brackets
The engine brackets that are riveted onto your frame are OK. You will
need the engine brackets for an LA318 though. The rubber insulators
for your Slant 6 should be able to be used for the LA318. You'll need a
larger radiator to keep that LA318 cool. You'll need the engine compartment
portion of wiring harness from a 318 Sweptline truck ['62-'68]. You'll need
to sort out a neutral safety switch for that auto tranny. I'm sure others
will add their :2cents as well.
Brandon
Correctly, and install the proper frame reinforcement spanner.
Obtain the correct driveline.
spoilerecw
City: Eakly
Thanks for all the info guys! I'm new to these year Dodges. What is the frame reinforcement spanner? Anybody have any pics of it? Thanks for all the help.
Brandon
Its a shaped steel piece that replaces the torched out part of the crossmember and bolts to the remnants of it. Its sort of like a crossmember, but it drops lower to fit under the auto trans. I have one I will sell when u get to that point. U also would need to see pics of where to torch the crossmember. If u take too much, the project gets more serious.
spoilerecw
City: Eakly
Do you have a auto trans crossmember also? Thanks!
Brandon
powerwagon54
City: Washougal
Post by powerwagon54 »
pm sent
Southernmagic76
City: Jefferson City
Post by Southernmagic76 »
PwrWgnDrvr wrote:Its a shaped steel piece that replaces the torched out part of the crossmember and bolts to the remnants of it. Its sort of like a crossmember, but it drops lower to fit under the auto trans. I have one I will sell when u get to that point. U also would need to see pics of where to torch the crossmember. If u take too much, the project gets more serious.
Can I get pics also? I have a 64 d100 im doing the same swap
http://imageevent.com/jeffc/techstuff3? ... =4&s=0&z=2
John :study :Thumbsup
