Guys
I need some help. I was told my truck had a Poly 318 but I cannot verify with the casting number that I found. I know it is a poly but need some help.
The casting number I found is 2284370.
Any help is greatly appreciated.
Thanks
Poly 318? Maybe!!
- thembsnyder
- City: Decherd
Poly 318? Maybe!!
A blind squirrel finds a nut every now and then
Re: Poly 318? Maybe!!
What year is your truck? The easiest way to tell is by the valve covers - if the bottom edge is scalloped, it's a poly; smooth, it's the later LA-318.
BB
BB
Grandpa's '66 W200
If it aint' broke..., I probably haven't fiddled with it.
Also, poly valve covers are held on with 2 bolts, one each end, thru the top. LA are held on with several, around the edges.
Poly head exhaust ports are this pattern: O O O O
LA ports are this: O OO O
- thembsnyder
- City: Decherd
Guys
Yes it is a poly 318. The valve covers are scalloped and have the bolts on the ends.
I am more wondering if it actually a 318 but I cannot find the casting number on any references.
- swptln
- City: East Brookfield
- State: MA
The year and cu.in. will be stamped on the front left cylinder rail right where the head meets the block. There is a machined surface there with a stamped engine id on it.
A casting number will not be specific to year only a range of years.
http://www.dodgesweptline.org/technical ... Colors.htm
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
Its a poly 318, absolutely no doubt whatsoever!
