440 engine swap
- City: holts summit
- State: MO
440 engine swap
anyone have any ideas on putting a 40 in a d100 frame where a 6 was originally ?? what mounts would I use ?? maybe from a 413 ??anyone done this...thx in advance for yer help
- State: MO
Re: 440 engine swap
lol..typonese is working...meant a 440 motor lol
- City: Clinton
Re: 440 engine swap
Mounts and brackets are available from several aftermarket vendors.
- MoJoe
- City: Holland
- State: MI
Re: 440 engine swap
I just finished my /6 to 440 swap this summer. I used 1976 or 77 big block truck motor mounts from a truck in the junk yard. I kept the slant six rubber isolaters and they bolted up to the mounts. I also took all the brackets for the alternator and power steering and trans throttle pressure. I got an oil pan from an old class A motorhome, it is a front sump. The wiring is very similar in length and placement so no modifications were necessary. I used the slant throttle cable but it is long and now makes a loop.(maybe not ideal but seems to work fine). I swapped from a np435 manual to a 727 and the trans mount was the same in my 1970 swepty. Earlier models may have a different crossmember setup from what I've read. I sent a car driveshaft out to be shortened and eliminated having to use the slip joint in the drive shaft setup. I ended up buying stainless steal shorty block hugger headers off from ebay and they work well. Later 440 blocks have a boss on the left side you need to cut off for these to fit. I used a van radiator because I had one and I ran out of money. The radiator required some cutting and fab work to mount it. Mounts are available from 440 source and some others, I used junkyard parts and I think and old motorhome would be easy to find, good luck!
Joe
Joe
1970 D100 Shortbox
1967 Plymouth Barracuda
1968 Plymouth Barracuda
1969 Dodge Charger
1969 Dodge Charger
- Roxyflash
- City: East Moline
- State: IL
Re: 440 engine swap
Is your truck a 1966 with hyd bellhousing
- State: MO
Re: 440 engine swap
it was a factory shifty truck but now it has an automastic in it..a 920..but I still have the hydraulic set up for the clutch up on a shelf..just the cylinder and stuff no bellhousing.
Re: 440 engine swap
Hola Holts Summit
Along with what Joe has said, add the following:
A set of OEM Center Dumping Exhaust Manifolds from any Car Division from 1959 to 1966 with a 361-383-413 or 440 will
bolt to a Big Block --- and will clear --- with out a hammer or torch. This is what was done for all Factory C.S.S./ H.H.P. Dodge
Trucks.
http://www.cssregistry.com/css/whatis.html
If you have not purchased the 440 yet ---- look for a 1972-1978 400 or 1962-1971 383 instead. They appear the same as a 413-426 Wedge
or 440 and as a total usage package they offer a better Bang-For-The-Buck. Your "bragging right's" will be aimed more at Performance Facts
vs cubes.
Rodger & Gabby
FltSgr@outlook.com
Colo Spgs
Trucks.
vs cubes.
Rodger & Gabby
FltSgr@outlook.com
Colo Spgs
Re: 440 engine swap
Duh wrote:Hola Holts Summit
Trucks.
vs cubes.
thats a very good point, ive been looking to swap my 77 360 out for a 70 383 from a coronet. needs rebuilding but thats where the fun parts come in
Rodger & Gabby
FltSgr@outlook.com
Colo Spgs
1966 Dodge D100 Custom SC SWB
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
- State: MO
Re: 440 engine swap
I have a 440..it came with the truck but its locked up from sitting...a local guy wants to trade me 3 383 blocks,2 69s one with the hp stamped on it and 1 from 66..just not sure if that's a good deal..the 66 has the crank n rods but id still need intake,heads distributater ,exhaust...etc,etc
Re: 440 engine swap
If it were me, I'd just keep the 440 until I had the opportunity to assess itschopped66 wrote:I have a 440..it came with the truck but its locked up from sitting...a local guy wants to trade me 3 383 blocks,2 69s one with the hp stamped on it and 1 from 66..just not sure if that's a good deal..the 66 has the crank n rods but id still need intake,heads distributater ,exhaust...etc,etc
overall condition.
Re: 440 engine swap
i also used a transmission crossover out of a mid 70's truck so all headers will work plus you can still find transmission mounts at the parts store real nice
- City: Eloy
- State: AZ
Re: 440 engine swap
I just purchased a 66 d100. It's been sitting since 1998 in az. It has a locked up slant 6. I have a 1970 chrysler new yorker with 440 and auto. Will the engine mounts work for this swap? Many Thanks for any info!
Re: 440 engine swap
The Chrysler mount brackets will not work. You need the Sweptlinepedalpusher wrote: ↑Fri Feb 05, 2021 8:25 pmI just purchased a 66 d100. It's been sitting since 1998 in az. It has a locked up slant 6. I have a 1970 chrysler new yorker with 440 and auto. Will the engine mounts work for this swap? Many Thanks for any info!
big block mount brackets. You can buy the rubber insulators at your
local auto parts store.
You'll need a tail shaft cross member, ideally from a '61-'68 D100/D200
donor. If your '66 had an automatic in it.... you're all set. If not, you'll have
to remove the bell housing cross member [leave the stubs, as they're
integral to the leaf spring perches] and get a spanner bracket to tie
the remaining stubs together.
- City: Eloy
- State: AZ
Re: 440 engine swap
Great info, thank you. Maybe you could put me in the right direction for cab mount brackets. The front ones are rusted up bad. Thanks!
Re: 440 engine swap
Check with Bud Thorp.pedalpusher wrote: ↑Mon Feb 08, 2021 4:42 pmGreat info, thank you. Maybe you could put me in the right direction for cab mount brackets. The front ones are rusted up bad. Thanks!
https://www.61-71dodgesweptlineparts.com/
- City: Winter Park
Re: 440 engine swap
Great post and I'm keeping an eye on it. I just bought a 413 out of a '65 Imperial for my '63.
- polyjon
- City: SHEERNESS
Re: 440 engine swap
Nice thread and 'food for thought' indeed.
What motor and what trans for my 64 D200???
Straight six and NP435.
Poly318ci and NP435.
383ci BB and NP435.
413ci BB and NP435.
426ci(bored 413) and NP435.
440ci BB and NP435.
All or one of the above with long-tailed auto box?
Not sure I can bring myself to cut-out the crossmember and fit a shifter.
Decisions, decisions lol...
383ci BB and NP435.
413ci BB and NP435.
440ci BB and NP435.
1964 D200 Sweptline trucker
Re: 440 engine swap
Do you have the big block flywheel, bell housing and starterpolyjon wrote: ↑Mon Apr 26, 2021 9:48 amNice thread and 'food for thought' indeed.
383ci BB and NP435.
413ci BB and NP435.
440ci BB and NP435.
for a hydraulic clutch set up?
- polyjon
- City: SHEERNESS
Re: 440 engine swap
Hi John,
Many thanx for your reply.
My 64 D200 has a six cylinder at the moment, but did have a 318 Poly.
I believe the bellhousing is dual purpose for the six and and 318???
But I have seen, not one, BUT TWO Big-block pre 68 bells for sale lol...
Although I have just rebuilt a 64 poly (from a Poly friend in the UK) I would like to go B/B.
Had some Barracuda's with the 318 LA but prefer a 383 or even a 440.
Spoilt for choice now...
