Leaking shift shaft seal A745
my5thmopar
City: Columbia
Post by my5thmopar » Sat Aug 09, 2014 9:25 pm
I found some fluid on the ground today and it seems to be coming from the shift shaft seal on the levers. It would have to leak after the cab is back on. :banghead Anyway...are there any tips getting those out without removing and rebuilding transmission. I'm thinking a small allen wrench or maybe a small hole and screw. I've never worked on one so I could use some suggestions. Thanks Craig
1964 D100 Utiline
1970 D200 CamperS
2002 Dakota
viewtopic.php?f=34&t=40251
Re: Leaking shift shaft seal A745
Post by Txas2step » Sun Aug 10, 2014 7:29 am
my5thmopar wrote:I found some fluid on the ground today and it seems to be coming from the shift shaft seal on the levers. It would have to leak after the cab is back on. :banghead Anyway...are there any tips getting those out without removing and rebuilding transmission. I'm thinking a small allen wrench or maybe a small hole and screw. I've never worked on one so I could use some suggestions. Thanks Craig
Should be pretty easy fix. Remove the 2 shift arms at the trans.. You can use a dental pic to remove the 2 seals. I think Rockauto has them, you might find them locally. :thinking
Rockauto:
http://www.rockauto.com/catalog/moreinf ... cc=1329353
my5thmopar
City: Columbia
Post by my5thmopar » Sun Aug 10, 2014 1:30 pm
Rockauto:
I ordered the seals from O'Reilly today. Dental pic hum....I'm thinking possibly 50 years in there...maybe they will come out!
1964 D100 Utiline
1970 D200 CamperS
2002 Dakota
hmaynord
City: fairhope
Post by hmaynord » Fri Sep 01, 2017 8:29 am
anymore suggestions?
I've got a Lisle tool for this, which should work if they're not too stuck.
Only risk looks like damaging the shaft where the seal rides. Thinking about trying to slip a piece of plastic between the shaft and seal before inserting the tool.
harris
1966 (late 65 titled as 66) D100 SWB 225-1, 3-on-tree
driving it since 12/03/71
hmaynord
City: fairhope
Post by hmaynord » Fri Sep 15, 2017 8:29 am
I'll report back, in case this might help someone else.
working on my back with the trans installed, I wanted all the help I could get.
here is the tool I used:
https://www.dropbox.com/s/09vw2xhws2to0 ... l.pdf?dl=0.
it took me a while to get everything set up, as far as where to position the handle and what kind of "spacer" to use between the silver part of the tool and the trans case. once that figured out, it went pretty well.
on the seal that was leaking, I could get a piece of plastic (middle of a coke bottle) between the shaft and the tool.
on the other seal (not leaking), the plastic went in fine, but then I couldn't get to tool in. Someone with stronger hands probably no trouble.
had to hit the end of the handle with 3 lb hammer several times, but each seal came out in 1 piece. Again, stronger hands probably don't need a hammer.
used a big washer and a socket to intsall.
so far no leaks.
harris
