Radiator HELP!!!
Spoon
City: Henderson
State: KY
Radiator HELP!!!
Post by Spoon »
Hello Fine People,
I need some help finding a replacement radiator for my 68 D100 318 LA, waterpump took a dump and the fan clutch destroyed the stock radiator. Id like to keep it as stock as possible. I brought the radiator to a local radiator shop and they cant even find a core for it. I dont mind an aftermarket aluminum one but money is tight. I do have local junkyards around but not having much luck.
Re: Radiator HELP!!!
Try another radiator shop. :2cents
62ute
City: Astoria
Post by 62ute »
Got mine from Leadfoot racing,they sell Champion aluminum radiators , I bought one for my 62 with a 440 works great and fit good too, had to modify mounting tabs some though, mine cost 210 bucks plus shipping, even has a built in tranny cooler, they have some generic mopar radiators, check out their website. Factory looking radiators are getting scarce and expensive.
Get a hold of Butch Romig.
romigbutch@gmail.com
He's the radiator man. He can probably re-core yours
for you :Thumbsup
Spoon
City: Henderson
State: KY
Post by Spoon »
Im learning more the re-cored radiators are in the $400 range. Where some of the champions or ebay aftermakets are in the $200 range. Was hoping for a lesser expensive fix since I have other parts to purchase as well. Thanks for the suggestions guys keepem coming.
w22
City: kingston
Post by w22 »
62 ute hit it on the head. Champion 2 row from ledfoot wiith built in cooler good to 450 hp for 210$
Spoon
City: Henderson
State: KY
Post by Spoon »
Thanks Guys I called Champion they have a really nice 3 row they are selling me for that price delivered and its really close to the stock one but its from a charger of the same year. :salut
Spoon
City: Henderson
State: KY
Post by Spoon »
If anyone needs to know the part # from Champion for this radiator the part # CC1640, just a helpful tip. Its really close just had to drill one of the mounting tabs it fits like a glove. Its a 3 row with a large core 26" wide and 24" tall.
JunkHead
City: San mateo
Post by JunkHead »
Spoon wrote:If anyone needs to know the part # from Champion for this radiator the part # CC1640, just a helpful tip. Its really close just had to drill one of the mounting tabs it fits like a glove. Its a 3 row with a large core 26" wide and 24" tall.
did you find that this radiator fit most dodges? iv got a 66 d200 318 5.2L....thanks! :usa
Spoon
City: Henderson
State: KY
Post by Spoon »
Its out of a 68 big block charger from the champion rep i ordered it from, apparently others are using this same one in earlier year sweptlines with big blocks...fits nicely with room to spare :Thumbsup
JunkHead
City: San mateo
Post by JunkHead »
Spoon wrote:Its out of a 68 big block charger from the champion rep i ordered it from, apparently others are using this same one in earlier year sweptlines with big blocks...fits nicely with room to spare :Thumbsup
Sweet! Called them today after i measured my tollerances and it looks like it should fit! I will let you guys know how it goes!
ThomasK
Post by ThomasK »
Not sure where your inlet and outlets are but I bought an early 80 Dodge Diplomat (can't recall if it is 3 or 4 core) new, for cheap. The only thing I did not plan on was the the best routed hoses where a bit large on the ID and I had to use readily available step-down inserts at the Radiator. (mine is a 64 D-100 Poly/Auto)
JimE
City: Glendale,
Post by JimE »
03 Hemi Ram 2500
JunkHead
City: San mateo
Post by JunkHead »
The champion radiator worked great with only a little bit of fabrication! I would 100% recommend it! :usa
demliag
City: Austin
Post by demliag »
I know this is an old thread, but I just installed the Champion CC1640 radiator. Only problem is that the lower outlet is 1.75 inch diameter, rather than the stock 1.5 inch diameter. Anyone know what lower radiator hose can be used for this?
Allen
demliag wrote:I know this is an old thread, but I just installed the Champion CC1640 radiator. Only problem is that the lower outlet is 1.75 inch diameter, rather than the stock 1.5 inch diameter. Anyone know what lower radiator hose can be used for this?
Allen
Sounds like you'll have to hit your local parts store and see what
they have in a universal flexi-hose. :idea :2cents
PwrWgnWalt
City: Butte
State: MT
Post by PwrWgnWalt »
I see Champion now has the CC6169 for our trucks... looks like a nice fit.
Anyone ever use ECP (Engineered Cooling Products) radiators?
The 26" sounds a lot like the same style and 1" coolant tubes the Champions use...
http://www.speedcooling.com/26-Small-Bl ... iator.html
PowerMan
City: Auburn
Post by PowerMan »
I have used the Champion style CC375 on three trucks (two 383 engines and one 340).
I have cut off the existing brackets as they are setup for 68-74 B and E bodies. I then welded on some 1.5" aluminum angle x 3/16" thickness, traced and drilled the four holes and it fits great. This way you can offset the radiator where ever you want. I have run the jaguar thermostatic fan clutches and that requires the radiator to be pushed forward so that the back face of the radiator is flush with the 4 bolt mounting surface on the core support.
