passenger 4 speed
- paffuffnic
- City: CORONA
passenger 4 speed
Has anybody put a passenger 4 speed in place of a granny 4speed (slant 6)??
- City: COS ( Colo )
Re: passenger 4 speed
Sir
Please give an hint of what year and soon the replies will start.
There is an model of the same truck transmission that is
1 - 2 - 3 - 4 vs the one and two - three - four that you have.
Rodger & Gabby
FltSgt@msn.com
COS
Rodger & Gabby
FltSgt@msn.com
COS
- paffuffnic
- City: CORONA
69 D100
Demulsion did it to his 68. I would like to do the same one day..... maybe.
If you're lucky..... you might come across an NP445 which has apaffuffnic wrote:69 D100
higher ratio for 1st gear and is fully synchro'd. The 23 spline
input shaft is what you're after. This should bolt right in too.
- paffuffnic
- City: CORONA
Thank's John...........am on the lookout.
- elacruze
- City: Jensen Beach
I'm installing an a833 in place of my NP435.
This is not a very simple swap. I have a Lakewood bellhousing to use for the trans, which is steel and allows me to fabricate engine mount bosses to weld on. I'll have to fab/tap holes for the slave cylinder as well. I'll also have to fab something between the shifter handle and automotive shifter mechanism.
I swapped a np445 into my 85 w250. 1st wasn't synchro'd. Well if it was my 1-2 was shot. There are np435's that have a 4.56 first gear, I believe the tag says 435a, find one of those and its a bolt in.
