were the same slant sixes used in cars and trucks
1970d100
City: ft lauderdale,FL
Post by 1970d100 »
Was there any difference between a slant 6 that came in a pick up and a car the reason im asking is because i found a spare low mile slant six very cheap out of a 68 valiant .
elacruze
City: Jensen Beach
Re: were the same slant sixes used in cars and trucks
Post by elacruze »
There are no significant differences. The /6 was originally increased to 225 cu.in. to accommodate truck usage.
http://www.slantsix.org/
'68 D200 Sweptline Camper Special, 318LA/4 speed
'68 Charger R/T 440/EFI/4spd/D60
My Build thread;
viewtopic.php?f=34&t=23316
You might run into pan differences, depending on what the Slant was in in the first place, but other than that, they are the same engines.
360scamp
City: East Renton
Post by 360scamp »
Aslo the end of the crank may or may not be drilled for a pilot bushing. If it is drilled for one it may not be finished drilled for the bushing but you can get either size. You can also use the needle "roller" bushing out of a Dakota pick up.
Jeffc
Post by Jeffc »
There is one main differace between the truck and car engines, the crank, heavier forged cranks in the truck engine. Other than the flange on the crank changing in 67 on all slants, cars or trucks there is little differances. Note, \6> the 66 and early cranks all have a smaller centering ring
than the 67 and later cranks (later cranks use the same size ring as the v8 engine, but one crank bolt hole is offset differant than the v8)
Dustbuster
City: Tulsa
Post by Dustbuster »
@ Jeffc
Can or does the centering ring need to be switched when mating an early block to a later model trans?
