drive shaft questions
- wideblock
- City: las cruces nm
- State: NM
you know the slip joint on a 2 piece half ton drive shaft? whats considered acceptable play when you twist the 2 in opposite directions? mine doesnt look worn at all, but does have a small bit of play in it, will the grease fill this in and not make noise? or should it be a tight slip fit? right now its what i would call a good slip fit, but not tight. real easy to slip in and out with all the grese and gunk cleaned off.
drive shaft
I would be no good on that for I didn't know they put 2 piece drive shafts on 1/2 tons, mine is a one piece
Both mine are also one piece, but SWB also.. LOL
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
They put both on the long bed , with a standerd trans , but both my 69 & 68 have the one piece , one auto & one standerd , trey a little twist is ok but no more then a 1/4 in on the high side , I ran one with about 1/4in for a couple years work fine under all kinds of driving :roll:
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
67 w100 318 3spd
LAND OF THE FREE
The 4 speed tranny used the 2 piece driveline set up for long bed D series
trucks[128"]. The automatic and A745 3 speed trannys used the one piece.
If you have a very slight bit of play, like a couple or so degrees of rotation
between your spline shaft and slip yoke.... that should be no big deal. As
you said... just put a good amount of grease in there... something with a
bit more tack ["sticky"]. The biggest hassle of installing a 2 piece driveline
is getting the carrier bearing/hanger in EXACTLY the right position so you
don't get that dreaded vibration..... got a laser? [LOL]
- wideblock
- State: NM
i always bolt in both rear and front joint, having the carrier hung, but loose. then duct tape a piece of kite string to both yolks, stretched tight and eyeball that the drive shaft is centered all the way down. then tighten the bolts on the carrier so far its worked like a champ. im damn sure aint running the truck in gear on jack stands and tightening the bolts like the book reccomends. thats just stupid!
- wideblock
- State: NM
hehehehehehehehe, good memory cowboy. yes i did drag a guy under my front bumper looking for where the clunk was coming from. but it wasnt me doing it! the book actually says to start thr truck in low gear in the jack stands and let the bearing self center, then tighten it up. if i had a concrete drive, maybe, but not on this dirt.
