Differential Fluid
Engine, transmission, rear-end, driveline, etc..
Differential Fluid
Postby JohnB » Wed Oct 21, 2009 4:17 am
What type and weight fluids are being used in front and rear differentials, 435/445 transmissions, and transfer cases? The manual says, 140 weight or 90 weight. What would be the difference in performance between 140 and 90? Also in my old FFPW, I used 50 weight oil in the trans and transfer case and 90 wt in the diffs. Are the multi 85W-140W a good choice?
JohnB
City: Gainesville
Re: Differential Fluid
Postby Trailmaster » Wed Oct 21, 2009 8:29 am
I always used 80W90 in the gear cases on my older stuff, never had any problems with it.
75 Duster 225/904/PS
Trailmaster
City: Ellicott
Postby MikeMc » Wed Oct 21, 2009 9:12 am
JB, I read about oil a while back but don't remember all the details :withstupid The different weights of oils are related to the ambient temperature on start up. The lighter weight oil carbons lube in cold weather while the heavier lubes better when it warms up. This is why a 10-40 motor oil is suppose to be so much better than strait 30 wt. The 10 is lubing on fire up and the 40 is doing it's job at operating temp.
Since you live down in Florida you could run the 140 wt. but if you don't have a bunch of oil leaks the 90 wt. will be less drag and get better fuel mileage.
MikeMc
Postby nfury8 » Wed Oct 21, 2009 2:40 pm
Unless you really work the truck, I would stick with the 80-90 or a straight 90w if available.
nfury8
City: KC, MO
Postby hmaynord » Fri Sep 01, 2017 8:34 am
probably been in there for decades. thinking about about evacuating and replacing.
any suggestions?
harris
1966 (late 65 titled as 66) D100 SB 225-1, 3-on-tree
hmaynord
City: fairhope
Postby JohnB » Fri Sep 01, 2017 3:19 pm
hmaynord wrote:probably been in there for decades. thinking about about evacuating and replacing.
any suggestions?
Drive it until trans, rear etc are warm; drain it and replace.
JohnB
City: Gainesville
Postby hmaynord » Fri Sep 01, 2017 3:40 pm
right. I always get my oil up to operating temp before i change it.
never thought about doing the same for diff.
harris
hmaynord
City: fairhope
Postby hmaynord » Sun Sep 10, 2017 10:08 am
for my chrysler RA36 rear axle, 66 SM states:
delivered from factory with 90W gear oil,
can use 90W as low as -10 F, and
above 90 F, use 140W.
down here, driving it below 45 F will be rare, but there will be a lot above 80 F, some above 90 F, and rarely above 100 F.
I'm going to leave the same fluid in year round.
maybe I can find straight 90W, but most is 80W-90.
should I use 80W-90 or 140?
half and half (never done that)?
does it matter that I have had over the decades a tendency for the right rear axle seal to leak into the brake drum?
harris
hmaynord
City: fairhope
Postby hmaynord » Wed Sep 13, 2017 11:01 am
forget it. found the answer.
as some of you probably already know, they make an 85W-140.
harris
hmaynord
City: fairhope
Postby marklein » Wed Sep 13, 2017 10:33 pm
Do not put synthetic in the trans. Will not be able to shift it. Too slippery for those aluminum blockers. Use heavier diff oils in hot weather and thinner in cold weather.
marklein
City: Red Deer
Postby hmaynord » Thu Sep 14, 2017 6:44 am
right. this is not synthetic. just the good old natural stuff.
as you say, manual says to change it according to expected temp.
like any other multi-viscosity oil, this 85W-140 should satisfy those requirements.
harris
hmaynord
City: fairhope
Return to *ENGINE/DRIVELINE HELP*
Who is online
Users browsing this forum: No registered users and 2 guests
