Manual to Auto
This area is for the A100 truck and van Enthusiast!
Moparsteve
City: Bakersfield
Manual to Auto
Post by Moparsteve »
Hello everyone,
I'm thinking of changing the 3 speed manual transmission to a 904 3 speed auto in my 65 A 100 pickup. I have a option of changing from the /6 to a v8 also. The things I have a question about are the dash mounting bracket and bezel. The cable length for the dash shifter to the trans and mounting the trans. I have a 65 a body floor mounted shifter
Assy with a cable operated /6 and V8 auto trans. What mounting bracket and bezel do i need to start this change?
Thanks for any help.
Re: Manual to Auto
Is the 904 from another A100 or the 65 A-body?
IIRC the A100 transmissions hang from belowthe crossmember while the car ones sit atop the rear crossmember. Tailshaft housings are totally different.
I think the dash bracket/bezel on A series vans is slightly different from those on D series trucks. I have owned one of each, but honestly don't remember how much.
Moparsteve
City: Bakersfield
Re: Manual to Auto
Hello Bucky
The auto is from an a body car. I know about the mount for the A100 on the tail housing and if I can find one I can change it.
The shifter bezel on the dash is special to the A100's if my inspections of pictures of the dashes are any indication then I need to find a A100 dash mount. What about cable lengths?
Thanks for your help.
Re: Manual to Auto
I just happen to have an A dash mount cable, bezel, shifter that I pulled from a junkyard van about 15 yrs ago. It was pretty damn long IIRC, and yes the bezel is different.
Wildergarten
City: Los Gatos
Re: Manual to Auto
Post by Wildergarten »
Moparsteve wrote:
Sun Dec 06, 2020 6:08 pm
Hello everyone,
I have the entire conversion available for a big block (only) from a '67 D200: dash, cables, shifter, linkages, speedo cable, brake pedal, A727-B transmission with torque converter and flex plate, crossmembers, driveshaft, cooling tubes, wiring for the neutral safety switch, and even bolts. It's been kept under cover, clean, and ready to go on to a pallet. The trans has been tested and worked perfectly. The only thing it needs is a new dipstick. PM me if you are interested.
Moparsteve
City: Bakersfield
Re: Manual to Auto
PwrWgnDrvr,
I sent you a PM, I think.
I was inquiring about the shifter you said you have.
If it's for sale? If I could get some pictures of the mounting bracket and cable length. If it's not for sale maybe the pics could show me what I really need.
Thank you for your help, Steve
Re: Manual to Auto
Got the pm Steve, haven't had a chance to search it out, but will endeavor to find it in the next couple days. PM me your email adr for an efficient reply. I can't, don't and won't text.
Moparsteve
City: Bakersfield
Re: Manual to Auto
Thank you for your reply, I didn't know if I sent the pm correctly. You don't have to be in any hurry the poor little pickup is getting in the Q in a bit.
Looks like you have quite a list of projects also.
I have a another project truck, 1970 D 200 and a "Plastic Truck" - 2005 Dodge Power Wagon AKA my baby, 285,000 miles and running strong.
Thanks for everything and stay safe, Steve
