Oil pressure gauge hose?
Posted: Sat Aug 13, 2016 6:53 pm
by Georgesee
I have a 65 A100 slant six and there is a small diameter hose that goes from a fitting coming from the oil filter to what I think might be the oil pressure gauge. Am I correct that the oil pressure gauge reads off of this hose? Does anyone know where a replacement hose can be purchased?
Re: Oil pressure gauge hose?
Posted: Sun Aug 28, 2016 8:38 pm
by dodgeboykim
Pick ups from 61 to 68 use one that probably is similar , But too short. Unless you can find a good used one you may have to fabricate one using the end going to gauge. One at pump is normal 1/8 NPT or should be. :thinking :thinking
