A100 Steering Column Removal
Posted: Sat Jan 23, 2010 7:01 am
by CornDog
Friday I was at a local junkyard and I tried to remove the whole steeing column assembly from a '65 A100 van and was not successful. I got everything loose but it still wouldn't come out. If I had a service manual, that would have helped... but I don't. I disconnected all of the wiring, the hardware for the column bracket, and removed the band clamp down low at the bottom of the column tube. Do I need a puller to remove tghe steering shaft from the steering box? Will I need to dismantle the column piece by piece? Thanks for your help!!
Justin
Re: A100 Steering Column Removal
Posted: Fri Jan 04, 2013 4:21 pm
by rhabneyA100
Justin, are you still working with your A100? Need parts contact me at rhabney1@att.net
Posted: Wed Jul 10, 2013 5:35 pm
by rhabneyA100
Justin,
email (rhabney@comcast.net) me your telephone number I need to ask you some parts questions. Robert
