A100 Steering Column Removal
This area is for the A100 truck and van Enthusiast!
CornDog
City: Jackson
State: MS
Post by CornDog »
Friday I was at a local junkyard and I tried to remove the whole steeing column assembly from a '65 A100 van and was not successful. I got everything loose but it still wouldn't come out. If I had a service manual, that would have helped... but I don't. I disconnected all of the wiring, the hardware for the column bracket, and removed the band clamp down low at the bottom of the column tube. Do I need a puller to remove tghe steering shaft from the steering box? Will I need to dismantle the column piece by piece? Thanks for your help!!
Justin
rhabneyA100
City: Atlanta
Re: A100 Steering Column Removal
Post by rhabneyA100 »
Justin, are you still working with your A100? Need parts contact me at rhabney1@att.net
rhabneyA100
City: Atlanta
Justin,
email (rhabney@comcast.net) me your telephone number I need to ask you some parts questions. Robert
