Hi all,
I was wondering where the washer fluid bag is supposed to be located on a '67 A-100?
also,what is the 2 inch hole under the battery box for?
thanks
washer bag
washer bag
'67 utiline
'77 ltd2
'96 Ram 2500
'75 power wagon,club cab
'69 sweptline (project)
'62 utiline (project)
'77 ltd2
'96 Ram 2500
Re: washer bag
If I recall correctly the washer bag hangs under the dash on the driver side in front of the pedals.
That 2" inch hole is used to route the cables out of the battery box. Supposed to have a grommet in there to keep as much moisture out as possible.
- City: Windsor, ONT
Re: washer bag
Washer bottle... to the left of the clutch pedal under dash.Bottle clips into a bottle holder then hose down to foot pump ...
Re: washer bag
Ya know. If your push pump for the washers dead, you can jerry rig the standard Mopar electric pump of that era with electic switch if need be. Hint- pumps the same as what fits 63-68 Fords you can find them for $20 online.BV1320 wrote:Washer bottle... to the left of the clutch pedal under dash.Bottle clips into a bottle holder then hose down to foot pump ...
