Pics please!!!!
- wide65
Pics please!!!!
For those with 4wd..... Can you send pics of your transmission mounted? the bell hauseing and t-case... I am turning my 2wd into 4wd and want a little help in design thoughts I have!
another one
Feel free to look at mine as well (70 383/auto W200) I'm in Lakewood. I also have an xtra small block stubby 727, 2 205s, and a cross member for a 4sp/4WD if that would help.
- wide65
Re: another one
GMan wrote:Feel free to look at mine as well (70 383/auto W200) I'm in Lakewood. I also have an xtra small block stubby 727, 2 205s, and a cross member for a 4sp/4WD if that would help.
I know this is REALLY OLD but do you still have these parts?
- Ruckus
- City: Stevensville, Montana
Re: Pics please!!!!
A divorced 205 is the cats meow... allows ANY 2wd to easily be converted...
78 W200 crewcab, 68 W200, 59 Willys Wagon, 52 Ford F5 Cabover
- Skunkman
- City: Nicholasville, KY
Re: another one
Is the 205 a direct bolt-in replacement for the 201 that came with it?GMan wrote: I also have an xtra small block stubby 727, 2 205s, and a cross member for a 4sp/4WD if that would help.
- Ruckus
Re: Pics please!!!!
If both are divorced, then the only change might be the yoke size. Some trucks came with smaller u-joints. I am not sure if the drivelines would need to be altered in length. My question would be, why bother? Have you broken your 201?
- City: Arvada
Re: Pics please!!!!
If you want to travel to Highlands Ranch, I have a 1970 Powerwagon. The transmission cover is off so you'll be able to take pics top and under!
jay66charger@comcast.net
1966 Charger
1970 D 100 Powerwagon
2007 Caravan
2005 Stratus
2007 Caravan
2005 Stratus
- 440SCOUT
- City: reno nv
- State: NV
Re: Pics please!!!!
IM INTERESTED IN PICS ALSO BUT I CANT TRAVEL THAT FAR, DO YOU THINK ANY OF YOU GUYS COULD TAKE SOME PICS OF THE MOUNTING SYSTEM ,DRIVE SHAFTS AND TRANSFER CASE SHIFTER AND EMAIL THEM TO ME??
THANKS IN ADVANCE
DOUG
SUMGMARIO@AOL.COM
THANKS IN ADVANCE
DOUG
SUMGMARIO@AOL.COM
- nfury8
- City: KC, MO
Re: Pics please!!!!
It isn't the best picture, but here is a pic of my crews chassis shortly after the cab was removed.
- 440SCOUT
- City: reno nv
- State: NV
Re: Pics please!!!!
THANKS FOR THE PIC.. IS YOUR TRUCK A 70 OR 71 IT LOOKS LIKE IT HAS THE 205 T-CASE BUT I DONT KNOW WHAT THE 201 LOOKS LIKE SO I HAVE NO BASIS FOR COMPARISON... DO YOU HAVE A MEASURE MENT FROM THE TRANS CROSMEMBER TO THE T-CASE CROSS MEMBER??
THANKS AGAIN,
DOUG
THANKS AGAIN,
DOUG
- Oldguy
- City: Reno
- State: NV
Re: Pics please!!!!
Maybe a better question would be, is there a difference between the transfer location on the W100 and the W200? Also, is there a difference between the 69 and 70? I have access to a 69 W100 for measurements if they are the same. Thanx Mike
- nfury8
- City: KC, MO
Re: Pics please!!!!
That is a 70 W200 Crew, I don't think the crew cab will affect anything.
I took measurements, then lost the paper.DOH!
I will try and remember to get better pictures and measurements tomorrow.
Weather is supposed to be awesome!
- nfury8
- City: KC, MO
Re: Pics please!!!!
Great day today! Till my MIG welder broke.
The camera worked though.
The 2 cross members are ~22.25" apart from center to center.
I used the rivet on the trans member and the holes in the frame
by the transfer case member as references.
The short shaft is ~11" center to center on the U-Joints.
The rear drive shaft is ~66" from center to center on the U-joints.
This is with a Dana 60 rear. You also get a nice view of the
monster 40" long glass pack there!
- nfury8
- City: KC, MO
Re: Pics please!!!!
This is a closed knuckle Dana 44 upfront.
No snow today, nearly 60 degrees!!
- wide65
Re: Pics please!!!!
Awsome Thanks!
- nfury8
- City: KC, MO
Re: Pics please!!!!
Another Snowy pic. This is a 2wd, reg cab, 8ft box frame. Of course I forgot to measure,
but looking at the pics, the T-case cross member would be just about between the rear
cab mounts, which are raised.
Eventually I will remember to crawl under my 71 and document how it was converted with
a married case. Been so busy with the crew cab I keep forgetting.
