Will a 75 w300 FS fit my 68
mopar_jason
Post by mopar_jason »
I have a 68 D100 i want to make it a 'W'.It already has a dana out of a d300 in the rear. Theres a guy near me selling a 75 w300 rolling frame with a 400 and a 727 w/ 55 thousand original miles on it. Will the front diff. and suspension fit 68.
will it fit
you'll have some modifications, but you can make it fit
Hoss
City: Berthoud
Post by Hoss »
You should not have too much trouble with it. If you plan on keeping the steering the same on you truck you may have to do some work on the steering arm and custom build a drag link for it. Spring purches should be the same. Make sure the gear ratio is the same or 1 tooth off ( 355/354 or 410/411)
Ken
68 W300 "Big John"
POWWAG
City: Maple Valley
Post by POWWAG »
You're gonna havta change master cylinders for the disc brakes.
Don
