318 poly cam replacement options
allsupj
City: Hayden
Post by allsupj » Fri Feb 26, 2016 12:16 pm
Anybody had good luck with a cam replacement in their 318 poly that they want to talk about. Brand, issues, performance, specs?
Re: 318 poly cam replacement options
Post by Kaegi » Sat Dec 03, 2016 7:14 pm
I had mine reground to suit my 1 ton needs for towing and hauling. truck has tons of power. I use delta camshafts in Tacoma WA since the 80s. they have done tons of flathead cams and a few V8 cams for me over the years. always happy with results. They can grind one however you want or recommend one for your needs.
so far have towed a couple loads in the 10K range including trailer and no sweat. Also few loads of gravel rolled over the scales at near 10K and could hardly tell loaded down. love polys
